overdrive transmission issues
chrisa
Post by chrisa »
I was wondering why my transmission kicks out of overdrive with my predator is turned all the way up???
RE: overdrive transmission issues
Too much torque for that Allison I would assume.
swanny
Post by swanny »
I havin' big troubles with my tranny as well, it shifts hard and kicks out of over drive even in the lowest setting. Is there and upgrade to work with the allison to make things work in tune?
greatwhitecracker
Post by greatwhitecracker »
swanny wrote:I havin' big troubles with my tranny as well, it shifts hard and kicks out of over drive even in the lowest setting. Is there and upgrade to work with the allison to make things work in tune?
"suncoast"
rydnhi4x4
Post by rydnhi4x4 »
Have you done the Trans-Go Jr. Kit yet. It's a very cheap mod that will help the tranny out. Your looking at 80 to 150 for the kit depending on where you buy it and the fluid cost depending on what your runnning.
http://www.thetruckstop.us
07 - CHEVY LBZ DURAMAX
All-Terrain T/A® KO - 295 75R16,
DYNOED ON 20 July 08 WITH -
PREDATOR SET ON THE 85HP TUNE / 423 RWHP - 709 FT/LBS
PREDATOR SET ON THE 120HP TUNE / 458 RWHP - 754 FT/LBS
