I do not own a GPS but would like to set the tire size from a GPS so the ole speedo will be correct. I currently have 265/75/16 on my 2007 2500hd
Can anyone with a GPS let me no what the correct tire setting would be , Thanks
Tire size with GPS
Tire size with GPS
2007 Gmc Duramax Allison 2500HD 4 wd 4 Door
Blocked and Fingered
Predator u7186
S & B Cold Air Intake
Damon
Predator u7186
Damon
jimmycurtisjr
RE: Tire size with GPS
I have the same set up you do and set the tire size to 30.5 and came out dead on.
2007 Gmc 2500HD
I have 285/75/16 on mine, but I had to enter 265/75/16 to get my speedo right on using a GPS.
http://www.thetruckstop.us
07 - CHEVY LBZ DURAMAX
All-Terrain T/A® KO - 295 75R16,
DYNOED ON 20 July 08 WITH -
PREDATOR SET ON THE 85HP TUNE / 423 RWHP - 709 FT/LBS
PREDATOR SET ON THE 120HP TUNE / 458 RWHP - 754 FT/LBS
Jimmy I take it you got your settings from a gps ? Anyone else ?
Predator u7186
Damon
Predator u7186
Damon
I have 265/75/16's as well. I use 244/75/16 and mine is dead on with my GPS.
jimmycurtisjr
Yes I used my GPS to get mine dialed in. From What I've heard it is the most accurate way.
2007 Gmc 2500HD
countrymac
Re: RE: Tire size with GPS
When you had yours set at 285/75/16 was your speedometer slower then what your GPS stated or faster?rydnhi4x4 wrote:I have 285/75/16 on mine, but I had to enter 265/75/16 to get my speedo right on using a GPS.
I used Diablo to change my tire size but it doesn't seem to have changed my speedometer at all which appears to be 2 mph slower then what the GPS states.
The truck came factory with 245/75/R16
Currently the truck has....... 285/75/R16 which is what is programmed using Diablo...
Any help is most appreciated.
RE: Re: RE: Tire size with GPS
When I used the tuner to set the 285's it didn't change it all. I just kept playing with different sizes until I got the right size which was 265/75/R16.
