Modify my tune (3.5L SXT)
I have the performance 89 tune installed and changed the tire size for 22inchs and increased the speed limit setting, but what else can i modify to add maximum performance or is there another tune i can install ? Some one please Help !
RE: Modify my tune (3.5L SXT)
Antone, it looks like you keep asking the same question, but in different threads. What mods have you made? The way the canned tunes that come with the predator are set up is to add timing in the base tune for example 91 Octane Tune adds some degree of timing what the amount of is I do not know. The 91 Octane CAI tune adds timing and fuel. So each canned tune adds alittle more timing and or fuel. It will depend on the type of mods, provided they are mild mods. If you install headers, high flow cats and maybe a cam and possibly new heads then that is when you would want to see a CMR Tuner that can dial the car in. Also with the predator you have the ability to adjust different parameters ie; Fuel @ WOT and Timing @ WOT. The key is to log the parameters and use the best gas availible to get the best performance. Just changing the thermostat out can help alot and the exhaust w/CAI. Firm up the shifts.
One other thing is to search the forums ie LXforums, charger and magnum to name a few for the answers and opinions of others and you can get an understanding of the capabilities the predator and different mods that can be made.
Jeff
2005 300c 5.7, Mods: 180* T-Stat, MagnaFlo-CatBack-Exhaust, JBA Shorty Headers, JBA Catless Mid Pipes, Billet Oil Catch-Can-Blue, Carbon Fiber Air Hammer-CAI, DS-Predator 9r07 crom and Eibach Pro-System Suspension, Mopar TC and Spartan Cam.
Thanks for responding, yes i am new to all this im not a gear head at all, i just started learning the basics. I have changed out my
exhaust added duals from the muffler back. I added a K&N air intake and installed the 89 predator tune. i GUESS WHAT I AM ASKING IS WHAT ELSE CAN I DO WITH THE PREDATOR or what else is there that can be done. If that makes any sense. I would love to get a response from the predator guys. And if possible can i send them my specs and maybe they can make some mods...i dont know
You should be just fine running the canned tunes.
Modifying any further should be done with a wideband or on a dyno...
The tunes that came in the Predator.
ok, i think im going to run out this 89octane and fill up with 93 and try that tune...any thoughts ?
Go for it.
venom_srt8
Re: Modify my tune (3.5L SXT)
do you have 22s on your car or are you try to fool the computer to think you have taller tires so it makes your car seem like you have a bigger gearantone302 wrote:I have the performance 89 tune installed and changed the tire size for 22inchs and increased the speed limit setting, but what else can i modify to add maximum performance or is there another tune i can install ? Some one please Help !
thanks
RE: Re: Modify my tune (3.5L SXT)
Unless they actaully are taller, changing the computer setting won't do anything except throw off the speedo and odometer. Anyway, shorter tires give a bigger rear end ratio, not taller.
venom_srt8
Re: RE: Re: Modify my tune (3.5L SXT)
Mike_Levy wrote:Unless they actaully are taller, changing the computer setting won't do anything except throw off the speedo and odometer. Anyway, shorter tires give a bigger rear end ratio, not taller.
thats what i meant if he had the 17s on but used the predator to lie and said he had 22s you no what i mean lol
RE: Re: RE: Re: Modify my tune (3.5L SXT)
Wouldn't matter. UNless the actual diameter and circumference of the wheel/tire combo was different then stock, no changes need to be made. Obviously when going from 17's to 22's you went to a lower profile tire. That keeps the total size almost, if not, identical.
