o2 sensors, put out engine warning light
shanno797
Post by shanno797 »
can one of you guys help me with my predator. i have taken out my resonators and now the o2 sensor warning light stays on. what way, using the predator, can i erase the light so it stays off. i have deleted the fault code with the predator, but the light is staying on? thanks
RE: o2 sensors, put out engine warning light
What is the code(s)?
shanno797
Re: RE: o2 sensors, put out engine warning light
Post by shanno797 »
mikel wrote:What is the code(s)?
the code is - P0032, Ho2S, Heater Control Circiut High, Bank 1, Sensor 1
RE: Re: RE: o2 sensors, put out engine warning light
Thats the front O2 sensor on the drivers side, may need to be replaced or has a damaged wire/harness.
shanno797
Re: RE: Re: RE: o2 sensors, put out engine warning light
Post by shanno797 »
mikel wrote:Thats the front O2 sensor on the drivers side, may need to be replaced or has a damaged wire/harness.
great Mike thanks. i am going to get that checked out today and see if either i can repair the sensor or replace it. do you think then i should be ok to put the light out?
RE: Re: RE: Re: RE: o2 sensors, put out engine warning light
Its just gonna keep coming back on until the problem is fixed.
shanno797
Re: RE: Re: RE: Re: RE: o2 sensors, put out engine warning l
Post by shanno797 »
Mike_Levy wrote:Its just gonna keep coming back on until the problem is fixed.
i thought that. but as soon as i sort out the o2 sensor defect, then with the Predator is can turn off the o2 sensor because i have taken out the cats?
RE: Re: RE: Re: RE: Re: RE: o2 sensors, put out engine warni
You can turn off the rear sensors. The fronts are needed. They're used to determine how rich/lean the air fuel mixture is, and adjust the fuel injection accordingly.
shanno797
Re: RE: Re: RE: Re: RE: Re: RE: o2 sensors, put out engine w
Post by shanno797 »
Mike_Levy wrote:You can turn off the rear sensors. The fronts are needed. They're used to determine how rich/lean the air fuel mixture is, and adjust the fuel injection accordingly.
what settings do i need to adjust to ensure that the engine warning light stays off? do i need to adjust the fuel rich / lean settings? if so can you advise on the settings? thanks Mike.
RE: Re: RE: Re: RE: Re: RE: Re: RE: o2 sensors, put out engi
you can disable the rear O2 codes so you don't get the check engine light, but gotta remember that, in order for the code delete/disable to work, the rear O2 sensors must still be plugged into the wiring harness.
they don't have to be installed in the exhaust piping - you can tuck them up outta the way somewhere if ya want, but they have to be plugged into the wiring...
if they're not plugged in, you will still get codes thrown and the check engine light.
shanno797
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: o2 sensors, put out
Post by shanno797 »
06MonteSS wrote:you can disable the rear O2 codes so you don't get the check engine light, but gotta remember that, in order for the code delete/disable to work, the rear O2 sensors must still be plugged into the wiring harness.
great. thanks for that. i will try that tonight and post on tomorrow and let you know how i get on. keep checking this in case i need you guys again!!!
shanno797
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: o2 sensors, put
Post by shanno797 »
hi guys, just to let you know, i have taken out the o2 sensors from the pipes. i have cable tied them all up neatly out of the way. i then got other o2 sensors the same size, cut off the leads, placed them into each slot where the old ones came out. i then cleared the code with the predator and all seems fine. the light on the dash is out!! brilliant. thanks to all for the great advise. gregg
You know you didn't have to spend the money on O2 sensors to fill in the pipes. You could have just left the stockers there or picked up a pair of plugs for $3 each
shanno797
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: o2 sensors,
Post by shanno797 »
Mike_Levy wrote:You know you didn't have to spend the money on O2 sensors to fill in the pipes. You could have just left the stockers there or picked up a pair of plugs for $3 each
i didnt but i do now!!!! i just used old ones that i had for an old truck of mine. thanks mike.
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: o2 senso
yeah, could have just left them in there... hehe... oh well, least ya got it corrected.
now, just gotta make sure that the zip ties don't melt and they don't bang around or hit anything else metal so that they ground out, causing another light to come on... hehe...
you should wrap them with electrical tape so there's no chance of them/the wires coming in contact with anything else up there where you tucked 'em up outta the way.
or, just put 'em back in the pipe.
only reason I mentioned that they didn't have to be in the pipe was because when a lot of people do changes to their exhaust, they put in new pipe without the rear O2 bungs, so they still have to plug them into the wiring, but can just tuck them up outta the way. didn't realize you still had them in the pipe...
anyway...
glad to here our tips/advice got it fixed for ya man!!
Return to “General Support”
