How safe is it to change transmission pressures?
e08789
Post by e08789 »
I have read that many claim the best mileage in 100HP setting with the U7170. The manual says to use Hard shift option in this setting. Is it safe to run this higher line pressure continually or will it eventually cause transmission problems?
sohfast94
RE: How safe is it to change transmission pressures?
Post by sohfast94 »
Actually less slip would equal less wear so it's night make last longer with that power level.
Insert Clever comment here...
