Spark Advance 91 Octane Tune
+ 2 degtees or more
+ 2 more
0
No votes
+ 2 more
0
No votes
yes/no
3
50%
yes/no
3
50%
Total votes: 6
seigl740
Post by seigl740 »
Hello All:
Thanks for all the help to a Newby! Since I reside in So Calif, I can't find more than 91 Octane Gasoline, 93 and higher are not available. Per the Forum, I have installed the 91 Octane tune with a 2 degree spark advance. The car runs great. would a couple of more degrees provide better excelleration, so long as it doesn't ping? In younger days we would advanve the spark a bunch before a race, and take it back down after. Your opinion is greatly appreciated. Any members with direct experience are welcome!
Best/ Bill
amsounds
RE: Spark Advance 91 Octane Tune
Post by amsounds »
Hi seiql740,
I would not advance it another 2* running 91 Octane! Motors built today have very close tolerances! If it misfires you can damage the internals! A extra hot day is all it takes to ruin a good motor! Two degrees is not going to make a big difference from the seat of the pants performance now! I would have the motor dyno'd for the setup you have! Gas is not as good at every station, some are better than others! You get some bad gas and you got a blown motor! Stick to what you have or run some illegal nitrous setup hidden of course!
2006 Roush Stage 1 F150
4x4 Supercab
Mildly Modified By Troyer Performance &
DiabloSport Tuning
www.Troyerperformance.com
www.Roushperf.com
Re: Spark Advance 91 Octane Tune
seigl740 wrote:Hello All:
Best/ Bill
Yeah, the 2* you added made it the same as the 93 octane tune...
seigl740
RE: Re: Spark Advance 91 Octane Tune
Post by seigl740 »
OK,OK.OK!!!
I went back into the 91 Octane Tune and changed the spark advance .5 degrees. Surely this is safe! I use only Mobil Gas and avoid all Jiffi, Arco and cheapo stations in general. If anyone can point me to a brand that offers 93 Octane or higher, I would be very appreciative. It is unfortunate when some one wants the performance og a GT-500, yet, only has a pocketbook for the Shelby GT!
Thing to remember is we have already optimized the timing in these tunes in our testing on the dyno.
40thmustang
Post by 40thmustang »
how can you go 2 degrees.. . you cant. you can go 10% advance but that is 1 degree.... ???
seigl740
Post by seigl740 »
My understanding is that each percentile is equal to one degree!
wayniac_00
Post by wayniac_00 »
each percent is a reflection of your intial timing from the factory. IE 20deg initial -10% = 2deg retarded I had to set mine back -16% on my mach 1 because the timing on the predator is to advanced (almost 4 degrees and this was recommend by a well know dyno engine builder and tunner) because of the predator not being set up efficiently for 32V mach 1.
Shaken
Re: RE: Re: Spark Advance 91 Octane Tune
Post by Shaken »
wayniac_00 wrote:each percent is a reflection of your initial timing from the factory. IE 20deg initial -10% = 2deg retarded I had to set mine back -16% on my mach 1 because the timing on the predator is to advanced (almost 4 degrees and this was recommend by a well know dyno engine builder and tunner) because of the predator not being set up efficiently for 32V mach 1.
Initial timing on a 32 valve Mach 1 is 10 degrees.
2003 Mach 1 K&N cai w/screen
Accufab 60mm Twin TB Steeda Tri-ax
Predator custom tune +1 lean 2k-4k, +1 lean 4k-7k
AFR 12.6-12.8 3/8" Roy Spacer IAC plate
Bassani O/R X 2.5 flowtubes to Delta 40's
w/factory tail pipes
wayniac_00
RE: Re: RE: Re: Spark Advance 91 Octane Tune
diablo sport said it was 20 degrees
seigl740
Post by seigl740 »
Shaken:
The owners manual on the U7140, not the small brochere that comes with it, states that yoy can add timing, globaly, up to 4 degrees and retard it by 10 degrees. Plus two, is two degrees? Don,t understand your statement of "How Could You" add two degrees that is?
Best/ Bill
Shaken
Re: RE: Re: RE: Re: Spark Advance 91 Octane Tune
Post by Shaken »
seigl740 wrote:Shaken:
Best/ Bill
Hi Bill,
My mistake wayniac_00 and myself have U7146 Predators which use % instead of actual degrees glad they fix that for others.
Shaken
Post by Shaken »
wayniac_00 wrote:diablo sport said it was 20 degrees
That kind of initial would make it really hard if not impossible for a starter to turn the engine over.
seigl740
RE: Re: RE: Re: RE: Re: Spark Advance 91 Octane Tune
Post by seigl740 »
Wheew!!
I thought I was going crazy!!!
40thmustang
Stock timing on a 99-04 gt is 10 degrees. on the u7146 the most you can advance it is 10% which= 11 degrees. Hope this helps, also if running the 1 degree advance then you must run atleast 92 octane, therefore at the pump it would be 93. I run 93 with 11 degrees and it is fine, no ping or nothin, also as soon as i get a new airfilter becuase mine is pretty dirty I will richen my wot fuel .5 .. I will let you know how that works when I do so
Return to “Predator Ford Gas”
