Does any body know what would get me the most out of my stock motor?I have a BBK CAI,75mm throttle body, delta 40 flowmaster cat back system,91 octane.
I mean how to do some fine tunning thru my preadator
2003 mustang gt w/AOD,U7146
02SonicStang
Re: 2003 mustang gt w/AOD,U7146
Just bought a Predator for my 02 GT Auto myself. How is the driveability with the 75mm TB? I seem to find it hard to moderate my throttle at light applications on the stock TB.chaddict wrote:Does any body know what would get me the most out of my stock motor?I have a BBK CAI,75mm throttle body, delta 40 flowmaster cat back system,91 octane.
Jerry
chaddict
RE: Re: 2003 mustang gt w/AOD,U7146
Well I am not to sure what you mean,but the throttle on mine is pretty responsive.you can IM me at [email protected]. I can tell you taht first I put the "Diablo sport "tune on and didn't like it Then I put in the "Factory HP tune" and that made loads of differance in my performance. And it will pretty much break the rears loose on demand with in reason.
Factory HP tune is simply a copy of your stock tune....no changes unless you make them yourself....
Mods for your Auto Gt.
The changes that really help my 01 GT Auto Vert get into the High 13's at the track was..
1. Predator performance tune ( Just leave it in drive and let the trans take over)
2. 3.73 rear ( should had gone to 4.10)
3. Dragon Plenum
4. Dragon 75 MM TB
5. CAI ( Using the Tuneable intake right now )
6. Flowsmaster "50" Catback
7. Wideband A/F meter ( I found the RAM type or In the fender CAI intakes leaned out my A/F at WOT. But using the Predator I was able to dial it in.The Wideband A/F meter is worth it's wt in gold along with the Predator. Or you could go pay for a Dyno tune every time you make a change to your GT.
Dave
3. Dragon Plenum
4. Dragon 75 MM TB
Dave
chaddict
RE: Mods for your Auto Gt.
Ok Mike, so if the Factory hp is the stock tune ,then where am I getting the,"Up to 150HP instantly" form the tuner at then? It sound like I am getting nothing in the way of HP and or torque? The diablo sport tune says it is for better MPG? Where is this hidden HP you all speak of?
