Fans run all the time U7192
Elwood
Post by Elwood »
my fans run all the time when at normal engine temp. is this normal?
Or...how do ilower on/off temps for two fans
'06 Vmax silverado 6.0
johan
RE: Fans run all the time U7192
Post by johan »
We do lower the fan on/off settings by 30 degrees in the default tune, so the fans will be running more with the diablo tune, you can always go and adjust them up if it bothers you, but they do run better a little cooler than the stock fan settings.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
jcollin160
Post by jcollin160 »
mine ran all the time also, i had them bumped up, mine were running in the winter at 10deg not necessary...
Return to “Predator GM Gas”
