Installing the Predator on '03 H2 Hummer
Hey just wanted to say that I love your programmers. I am now trying to install a predator programmer on a 2003 H2 Hummer. It loads up, but when I try to install a tune, it says "not available for this vehicle". Does this have to return to you guys for reprogramming? It would let me get into the factory tune and now has a check engine light, which I will look at tomorrow. I appreciate the help. Keep up the good work!
RE: Installing the Predator on
do you have the correct Predator?? U7195 ??
What revision is on this tool?
Please check and post up this info.
'03 Hummer
Yes, the programmer is a U7195, as for the revision, where do I find that info? I double-checked the VIN # and the 8th digit is U.
RE:
The revision is listed on the top line of the main screen of the unit when it is booted up.
sorry the last post took up so much room...that is my '05 GMC Sierra 1500 Shortbox. I have 9mm JBA wires, Air Force One cold air intake, Granatelli MAFS, Flowmaster exhaust with dual tips, all synthetic oils, and of course, a Diablosport Predator programmer! This week it goes to the local dyno to get some hard numbers. I'm not sure what I'll get because I have 6" lift and 35" Toyo Mud Terrains, but I think the numbers will be all right. I'll post the results at the end of the week. Thanks, Keoki.
Looks like you have the incorrect programmer for the 03, the latest rev for U7195 is 2.04 but you list the name being GM06 which covers 06-07 gm trucks(old body style). So i would say you have the wrong part number.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
