1/4 mile logs any changes
supercatxr7
Post by supercatxr7 »
Anybody want to take a look at my 1/4 mile logs and let me know if you would make any changes? Car is a 06 Monte Carlo SS 5.3 v8.
1/4 mile runs start at 1:40 and 5:34
Should I add a little more timing?
2006 Monte Carlo SS 5.3 V8
U7191
RE: 1/4 mile logs any changes
hooolllyyyyyy craaaaaap dude... you logged EVERYthing....
hahaha...
daaaamn....
you get much better data with only logging what you need, as the sampling rate will be faster with less parameters to log...
all you really need to log is:
air fuel ratio (Equivalence Ratio)
commanded throttle position
engine speed (RPM)
long term fuel trim bank 1
spark advance
total knock spark retard
I wouldn't add more timing... looks like you did already... you're up at 33* at WOT...
mine's only at 28* at WOT...
AFR looks good, there's no KR at WOT...
all the numbers look good man...
supercatxr7
Thanks! Yea, sometimes at the track I just log it all! I'm trying to squeeze a 13.3 et out of the car, but looks like I'm maxing the timing pretty good now.
U7191
