(data logging) so what does this mean????
Aaronr
Re: RE: Re: RE: Re: (data logging) so what does this mean???
Post by Aaronr »
Aaronr wrote:Biggest change is the way it ideals. When I made those changes the truck ideals a lot smother.
Seams to response faster but its really hard to tell if the truck is any faster.
Mike can I download the tune on to my computer and rename and upload to tool?
I just want to creat a tune for the winter and summer.
I live in AZ and in summer gets about 120 degrees here problem have to tune it for the summer time.
Thanks again for you guys help.
If live AZ I would take you guys out for some beers.
bump?????
Still waiting for answers please??
RE: Re: RE: Re: RE: Re: (data logging) so what does this mea
Hey Aaron...
yes, you can save a copy of the tune that you have in your car - with the adjustments you made to it.
go to Options - custom tune - and select "read extra tune"
this saves the tune you have in the car to the predator.
then, when you hook it up to your PC, you would go to the export menu, and select the "extra tune" to export.
Just found this out this weekend myself...
Aaronr
Post by Aaronr »
06MonteSS,
I'll check out at lunch time. I'll let know what i come up with.
Thanks again.
Aaronr
Re: RE: Re: RE: Re: RE: Re: (data logging) so what does this
Post by Aaronr »
06MonteSS wrote:Hey Aaron...
06MonteSS,
I dont have that option in my predator. I paid same price for my tool as you, but i have less options. what is the deal here.
Aaronr
Post by Aaronr »
bump?????
MIke or John
Can you help me with this options.
There is an option in the U7198 called 'save current data' or something to that effect.
Johan is not in the office right now, but I'll ask him in the AM.
kcstone529
Post by kcstone529 »
Aaronr,
i have the same truck and set up as you and was just wondering if you would be willing to let me know what parameters you modified and to where you set them at!
thanks! kcstone529
Aaronr
RE: Re: RE: Re: (data logging) so what does this mean????
Post by Aaronr »
Please name the mods that you have.
I would do some logging before i would change anything.
u7198 2.13v will not write a log file for you it only monitor real time data.
Check out this link below.
http://www.diablosport.com/index.php?na ... opic&t=917
monitor these items below
drive at 65 to 70mph
long term fuel trim bank 1
long term fuel trim bank 2
Wot
xygen sensor 1 of 1
xygen sensor 2 of 1
Aaronr
Post by Aaronr »
mikel wrote:There is an option in the U7198 called 'save current data' or something to that effect.
MIke have talked John about saving you current tune down?
RE: Re: RE: Re: RE: Re: RE: Re: (data logging) so what does
Go into your "Options" menu -- do you have a selection for "PC Communication" ?? This menu option is used to upload/download to and from your PC.
It's in the Options menu somewhere... if you don't have that, please list everything you have under the options menu.
From the main menu:
Tune it/
troubleshooting/
read extra tune
This will allow you to export the tune as 06MonteeSS described.
Aaronr
Post by Aaronr »
From the main menu:
Tune it/
troubleshooting/
read extra tune
Thanks Mike that worked. So after I download it to my computer and rename the file and upload it to the tool. Will it show up under my install tunes as a custom tune?
Thanks for the help.
Glad you got it.
Yes, this will allow it to show up as a custom tune.
kcstone529
so do i only monitor my o2 sensors at WOT? or Do i need to worry bout them while cruisin at 60-75mph too?
Aaronr
Re: RE: Re: RE: Re: RE: Re: RE: Re: (data logging) so what d
Post by Aaronr »
kcstone529 wrote:so do i only monitor my o2 sensors at WOT? or Do i need to worry bout them while cruisin at 60-75mph too?
kcstone529
Just monitor the 02 sensors at Wot.
I would monitor long term fuel trim bank 1
long term fuel trim bank 2 At 65mph and 70mph
and let me know what you get.
Return to “Predator GM Gas”
