I programmed my 2008 Corvette with my Predator that arrived today and now the car is throwing P2066 and the gas gage doesn't work. Seems like a very strange coincidence. Any ideas?
Fred
2008 Corvette - P2066
CANUCKPREDATOR
RE: 2008 Corvette - P2066
What revision of software on your Predator? It's at the top of the main screen when you start it up.
it's trying to save you the pain at the pump...
Strange, let me know what happens when you clear it.
Don't worry this happens every once in while with those cars when you program them. Take the battery cables off and connect them to gether for about 2 minutes and put them back on ground first and everything will go back to normal.
Insert Clever comment here...
This is because the serial was BUS was interrupted again thus it works again. Just reprogram and then do what I said and it will work.fraub wrote:I did clear the code with no luck. Next, I sent the Diablo performance tune back to the car and all is right with the gas gage again?
