changing parameters frequently bad??
rt4drizzt
Post by rt4drizzt »
just wondering how often can u change parameters in a tune without hurting the engine? and how often do u need to set shift firmness because unlike other parameters, this setting doesnt get tagged in the predator that it was set. any input?
RE: changing parameters frequently bad??
Once you set firmness, it is set until you restore the stock tune.
You can adjust things as often as you like.
Thnaks
Quick
Post by Quick »
I think I heard that the EPROM in the PCM is good for 10,000 re-writes.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
ZMagnum
Post by ZMagnum »
I believe it's more like 100,000.
concoursd
Post by concoursd »
10,000 rewrites means you will never wear it out. Besides, i bet the diagnostic port plastic is only good 5,000 before it breaks for shorts out...lol
ZMagnum
Re: RE: changing parameters frequently bad??
Post by ZMagnum »
concoursd wrote:10,000 rewrites means you will never wear it out. Besides, i bet the diagnostic port plastic is only good 5,000 before it breaks for shorts out...lol
That's why I use a m/f OBDII extension cable to plug into.
fordomatic69
Post by fordomatic69 »
Great Idea.... where did ya get it?
Fordomatic Says:
"I've heard of Vaporware... but I've never actually seen it" :lol:
http://www.twincamlubricants.com - For all your synthetic lubricant needs. Order Online and save over retail.
mnunes
Post by mnunes »
I got mine at scantool.net. It's a 6-foot cable with a right-angle connector for the OBD port and a straight connector for the Predator to plug into.
J1962M Right Angle to J1962F, 6ft (144301) = $16.95
I routed the cable behind the center stack and leave the Predator side dangling near the glovebox.
