Can't download revision.
I noticed that there was a revision for my U7155. I downloaded the revision and the downloader to my computer. When I try to put it in to the Predator I keep getting a"Application is missing or corrupt" message after some of the packets are transferred. I followed the steps to try to uncorrupt the tuner but I am not sure if I have succeeded or not. Should it give a message if it has been repaired?
Any suggestions?
Any suggestions?
RE: Can
Check the size of the CROM file that you downloaded - right click on the file, select Properties. Compare that to the size of the file listed on the Support page for 7155. I am guessing that you do not have the entire file. Sending the CROM file to the Predator should take a while.
johnc <at> diablosport.com
Are you downloading from a wireless connection?
I'll try emailing it to you...
May need to try a different PC?
This is odd...we have hundreds of people download these files every week, check your firewall connections?
Can you call so we can walk you through it?
