LS3 Predator Tune - Code P2066 now...
hugo
Post by hugo »
I have a U7194 with the latest CROM in it for the LS3 08 vette.
Flashed it, drove it about 100 miles and now I get code P2066. I cleared the code and it came right back. I put the stock tune back in and it seems fine now.
P2066 says fuel level sensor.
What next?
2008 Corvette Coupe
Victory Red - MN6
-----Modifications-----
Predator Diablo Tune
Corsa Sport Exhaust
BoostFrenzy
RE: LS3 Predator Tune - Code P2066 now...
Post by BoostFrenzy »
yeah if you enter the tune parameters after a flash you'll get that code and the fuel gauge will not work, you can clear the code and the fuel gauge will work again however the fuel computer will not (0mpg when stopped / 70mpg when moving no matter what), i let mike know about it and hopefully they correct it...
meanwhile reflash or reset ecu to fix
-2008 C6 Coupe 1LT/QX1/MN6
hugo
Post by hugo »
So how do we edit parameters now then? I went into the params but didn't reflash - just poking around... If we edit a parameter and reflash is it okay?
2008 Corvette Coupe
Victory Red - MN6
Corsa Sport Exhaust
BoostFrenzy
yeah if you flash after "poking around" it's fine, hopefully they fix it
hugo
Post by hugo »
Okay thanks.
2008 Corvette Coupe
Victory Red - MN6
Corsa Sport Exhaust
akeyzoo
Post by akeyzoo »
Just experienced the same fuel error and indeed the problem was corrected by installing a new tune. I will miss that 99.9MPG tho...
Chris
Return to “Predator GM Gas”
