2008 F 350 Throwing DPF CODE w/ V.9r02
apex54321
Post by apex54321 »
I'm having a problem with a u7164 Predator tuner w/rev # V.9r02 causing "below or low level" DPF code, starts with check engine didn't get the code number. New 08 F350 Super Duty, 6.4L w/4200 miles and have added cold air intake and DPF back exhaust system. I'd like to find problem help???
cole
RE: 2008 F 350 Throwing DPF CODE w/ V.9r02
Post by cole »
can your post your calibration id. Options/Troubleshooting/Show Calibration ID As well as posting the exact trouble codes from the predator.
Cole Stevens
apex54321
Post by apex54321 »
Hi Cole:
I didn't get the code but I did speak to some one in Diablo Sport Tec. support this morning. And he seemed to think it wasn't related to the Predator so, to better pin down the proble I'm going to operate the truck on the factory settings and see if the problem comes back. I'll le tyou guys know what happens.
Thanks!
Bruce
VPO
Post by VPO »
If you have an AFE Stage 2 Air intake on the 6.4L, they are throwin a couple of codes. AFE still has not fixed it. I believe it is from too much hot air gettingin, as the Air-Raid & S&B air intakes dont throw any codes.
apex54321
Post by apex54321 »
VPO:
Thanks I have installed an air intake. Do you know if I Should go back to the factory until this is repaired.
Bruce
VPO
Post by VPO »
apex54321 wrote:VPO:
Bruce
It all depends if your dealer is "mod" friendly. Personally it doesnt take that long to change, so i would change it, just to prevent the from blaming IT.
concoursd
Post by concoursd »
Airaid has also confirmed that their intake will throw code P2002 DPF threshold error for newer 2008 calibrations. Early 2008 calibrations from Ford had a different threshold for that code and those early calibrations were used on the test trucks for these aftermarket intakes.
cole
Post by cole »
i spoke to marketing this morning and they are going to contact AirAid and AFE to get the problem child intakes so we can develop calibrations for those intakes.
Cole Stevens
