i have a 2002 ford explorer sport. it has a 6 pin MAf setup but will very soon have it blown and want to up the sensor.
my question... is there a connector i can get with this maffia to plug into my 6 pin harness and on the other side the 4 pin lighting maf unit? and what exactly happens to the IAT sensors?
thanks,
ian
6 pin harnessand 4 pin maf
RE: 6 pin harnessand 4 pin maf
All Mafia's come wired for 6 pin. The two extra pins are straight thru circuits only, just in case your IAT is in your MAF sensor. Whether they are used or not doesn't matter but they are preinstalled in case you need them. If you are converting from a 6 pin sensor to a 4 pin then you will need to purchase an IAT sensor and connector separately and install them. The wire terminals in the MAF connector are the same as an IAT connector so its as simple as removing the two pins from the maf connector and installing them in the IAT connector. No hacking up the wiring is necessary...
Kevin@Diablo
Kevin@Diablo
