How to get rid of this ST and LT Knock
LXSRT8
Post by LXSRT8 »
1. U7135
2. 9r05
3. 2007 Dodge Charger SRT
The enclosed log has a note of two time periods I would appreciate someone looking at for me.
This is where I went from rolling at around 35 MPH and floored it up until the mid 70 range.
This is the Canned 93 Octane Tune W/O CAI on my 2007 SRT Charger.
The car is stock except I have a Mopar CAI on it.
I just came from a BP station with my 'low on gas' light on and filled it with 93 octane gas and I could not find any sticker that said it did have any ethanol in it.
The ST and LT KNock values area really high and I can not see any correlation between them and the trans shifting. What can I do to reduce/eliminate it?
I did one run with the stock tune and it had 0 for LT retard and 4.5 for ST Retard.
Sure would appreciate the help.
I really like the way this car pulls with the 93 performance tune but I am worried about hurting the car with this much Knock going on.
RE: How to get rid of this ST and LT Knock
Well number one, put CAI tune on the car. It adds fuel which is one way to reduce knock. Why are you running without it if you have a CAI? Second, the SRT8s are very prone to knocking. I had problems with my 300C SRT8 and I'm having problems with my Grand Cherokee SRT8. Trying to work with Johan to find a solution, but nothing seems to be working (BTW Johan, I'll have a new log or you tomorrow at some point).
claude9039u
Post by claude9039u »
Get a CMR tune it will work wonders.
Not always. I have a CMR tune (e-mail from Modern HP) and Johan is having to tweak that even to get rid of the KR.
05MAGNUMRT
Re: RE: How to get rid of this ST and LT Knock
Post by 05MAGNUMRT »
Mike_Levy wrote:Well number one, put CAI tune on the car. It adds fuel which is one way to reduce knock. Why are you running without it if you have a CAI? Second, the SRT8s are very prone to knocking. I had problems with my 300C SRT8 and I'm having problems with my Grand Cherokee SRT8. Trying to work with Johan to find a solution, but nothing seems to be working (BTW Johan, I'll have a new log or you tomorrow at some point).
I was about to say that too, if you have a CAI why don't you have the tune with CAI, if they made it an option it's for a reason I think.
Put the CAI tune on and see if it helps, that the first thing you should do.
johan
RE: Re: RE: How to get rid of this ST and LT Knock
Post by johan »
You NEED to run the CAI tune, you are running too lean with a CAI and the predator non-cai tune.
Also, these cars are notorious for getting oil in the intake, a catch-can will solve that issue.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Twin catch cans for best results. :)
Quick
Post by Quick »
Did you run out of braid cover for that last run to the manifold :)
I'm thinking about the can on the oil breather. It will be interesting to see if you catch anything there.
Most of the time the air flow will be going through the can backwards. Shouldn't be a problem. What
it's there for is to catch a "burp" resulting from an extreme, abrupt change in manifold pressure that
would send an air "wave" in the reverse direction. Without forced induction I don't think that happens
to any extent with our cars. What it would catch is spilling oil into the breather when filling that would
then get drawn into the intake?
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
Nah I have a whole roll of covering. I just replaced that hose and never got around to covering it. The can has been catching oil. I knew it would because with the stock intake the filter was covered in oil and there was a pool in the bottom of the airbox.
