180 stat settings
180 stat settings
i have a 2006 charger rt w a CAI im using a 180 stat . my tune is the 91 CAI tune. wat should i set the fan settings to?
RE: 180 stat settings
Can't speak for the other guys, but I keep my LS at 187, and the MS and HS at 196, both with A/C on and off.
Where it opens might effect your choice. Everybody calls the Motorad/ValuCraft/Autozone 4128 a 180* T-stat but it opens at 185*. The Jet opens at 180*.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
I am running the 4128 t-stat, and a customized 93 octane CAI tune. Under normal condtions my EVIC shows 186*F.
Some time ago I inquired of DS what the temperature difference was from FAN-ON to FAN-OFF. The reply was 10*F.
So, in order to keep the low speed fan from running continuously, I have my LS temps set at 197*F and the MS and HS temps set at 207*F.
"It works for me."
"It works for me."
Re: RE: 180 stat settings
Yep. I think the fan on to fan off might vary a bit (I've got a 2006 SRT8). I tried mine and the low speed FAN-ON to FAN-OFF seems to be about 4*. That was from very unscientific experimentation. Stand up front and wait for fan on, rush to driver's window and look at EVIC display. Repeat for fan offDESIRAY wrote:I am running the 4128 t-stat, and a customized 93 octane CAI tune. Under normal condtions my EVIC shows 186*F.
"It works for me."
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
whatever_weirdo
Re: 180 stat settings
mikel told me to set all fans 20 degrees lower then stock works for mehozuki wrote:i have a 2006 charger rt w a CAI im using a 180 stat . my tune is the 91 CAI tune. wat should i set the fan settings to?
my cmr tuner agrees also
2006 300c 5.7 dynomax exhaust reso delete afe stage 2 cai 180 t-statand a comp cam now cmr tune with 9r12
- fordomatic69
. I set my LS at 191* and HS at 202? It's something people should play around with to get what they like. You're not going to hurt anything.[/quote]
I used Quick's spreadsheet of 192 and 203 (I think he dropped it to 191 and 202 since I saw it last). I have it printed on a piece of paper and I put it in the glovebox with the registration and insurance slip...
Fordomatic Says:
"I've heard of Vaporware... but I've never actually seen it"
http://www.twincamlubricants.com - For all your synthetic lubricant needs. Order Online and save over retail.
What and where is the Quick's spreadsheet u speaketh about???fordomatic69 wrote:I used Quick's spreadsheet of 192 and 203 (I think he dropped it to 191 and 202 since I saw it last). I have it printed on a piece of paper and I put it in the glovebox with the registration and insurance slip...
- fordomatic69
RE: Re: RE: 180 stat settings
Go to this thread:
http://diablosport.com/index.php?name=P ... thermostat
8th Post Down. Just copy and paste it to any word processor or spreadsheet (Word, excel, Openoffice, wordpad, whatever).
Thanks Quick
Thanks Quick
Fordomatic Says:
Thanks. Those are just my personal preference. I have the Motorad/ValuCraft T-stat that opens at 185*. I think the Jet opens at 180*.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
- fordomatic69
I have a Lingenfelter Failsafe 180* thermostat.... not sure if it opens at 180 or 185? Couldn't be bothered doing the metric conversion and just used the spreadsheet from Quick...seems to have worked for me.
Fordomatic Says:
