Having trouble turning rear O2's off 03 Cobra
I have tried everything, read the manual multiple times and I am still very confused. I can't seem to get the rear O2's to turn off. I have tried turning each bank off individually, no dice. Tried turning each bank off then both with the O2 config, still it throws the code. Can you please walk me through exactly how to do it. I have to pass emissions soon and need to get this done.
RE: Having trouble turning rear O2
I hate to say it, but you will not pass with the rear O2s turned off.
You should just turn off the O2 codes listed under OBDII in the Predator, then reinstall the tune.
How do I turn off the codes? Just clear the codes.
In Arizona they don't do a visual check or hook you up to the sniffer, they plug it in and if you have no codes you are good to go.
