Dynoing SRT Cherokee in 2wd
Can anyone share thoughts on the easiest way to do this? Can it be done through CMR? Or just pull the front shaft?
RE: Dynoing SRT Cherokee in 2wd
Two ways that it can be done. The preferred way is to pull the front driveshaft. Its also possible to simply pull the electrical connector on the transfer case, though Chrysler warns against doing that.
I heard it could be done in the tune. Thanks for the help! About to dyno our single turbo.
Be sure to set it in Dyno Mode, and pull the front driveshaft....
