What ecm do I need
chaser1602
What ecm do I need
After waiting for the sky to fall and the world to end I figure the only way to use my predator is to get another ecm.
2000 ford f150
PN#u7153
On power up-
predator v.8r2
performance tune
diagnostics options
disclaimer
turn on ign.
veh not in d/b
this is the pn# on the box and what I get when I turn the tuner on.
Any idea as to how to ID the correct ecm so I dont waste any more money on this tuner
2000 ford f150
PN#u7153
On power up-
predator v.8r2
performance tune
diagnostics options
disclaimer
turn on ign.
veh not in d/b
chaser1602
RE: What ecm do I need
Thank you Diablo for your great and continuing support
update your predator... I am assuming this is a used piece? All the instructions are found on this site under downloads, and have been for a couple years...
What's your calid? Go to options>troublshooting>Show Calid
Insert Clever comment here...
chaser1602
Re: RE: What ecm do I need
rhag7aysohfast94 wrote:What's your calid? Go to options>troublshooting>Show Calid
chaser1602
Yes it is used.As far as I know there has not been an update for calid rhag7ay.That is why I thought about changing ecmdynometer wrote:update your predator... I am assuming this is a used piece? All the instructions are found on this site under downloads, and have been for a couple years...
that had a calid that the preator would support.My ecm was flashed at the ford dealer and it can not be returned to original
RE: Re: RE: What ecm do I need
try updating your predaotor first. the updates are free. go to support->downloads-> and select U7153 in the drop down. All of the software and instructions are on that landing page.
Current update is 9R03
Yeah all you have to do is update the predator and the new calibration is in the new release.
chaser1602
Re: RE: Re: RE: What ecm do I need
Went to the download link and tried to download the program.No worky.Cant open it up from there,cant copy and paste.Cant ttype it in,and do a search.(Step 3)concoursd wrote:try updating your predaotor first. the updates are free. go to support->downloads-> and select U7153 in the drop down. All of the software and instructions are on that landing page.
It also says to allow the predator tosave a copy of the original backup file from the pcm in the car in step 1. Cant do that either
RE: Re: RE: Re: RE: What ecm do I need
Emailed.
chaser1602
Hey all.Got it all worked out and working.Thanks for the help
