Adjustments for 160 Thermostat
vettefun
Post by vettefun »
I have a 1999 corvette and I just got the programmer. I read on another thread that I need to goto "adjustable parameters" to disable CAGS. What about Fan settings. Where can I manually adjust those, or do I only do It from the performance tune and get the 30 degrees less setting only.
Also, where is the "adjustable parameters" setting in the predator.
Greg
RE: Adjustments for 160 Thermostat
Once you go into the Tune it menu, you will gat the option to 'install tune' or 'modify tune'.
Selecting 'modify tune' and then 'modify parameters' you will get a list of adjustable parameters that you may modify including fan on/off temps and CAGS on/off.
Return to “Predator GM Gas”
