Dataviewer 3.1 live data streaming Update for U7158 predator
jg04lightning
RE: Re: RE: Re: RE: Dataviewer 3.1 live data streaming Updat
John,
Do you guys have a swap out program so I can get the latest predator with more memory and has the latest protocol?
We are looking into a hardware upgrade program right now.
jg04lightning
Mike,
Thanks for the response. BTW the tune you sent to me with modifed part throttle shift points should be standard. Thanks again.
Insert Clever comment here...
jg04lightning
Brian,
Mike sent me the 5700_shift_tune.frg initially. If it was you who modified the part throttle shift points, I think it definitely should be a standard in your canned tunes.
The additional tuning modifications you made on the above tune have been working quite well. The WOT shifts occur faster and causes the tires to bark between 1-2 and 2-3.
The 100 octane modification to this tune was a real kick.
You definitely know what you are doing.
I look forward in continuing our work. I know there is a lot more power you can squeeze out of my Lightning
jg04lightning
Re: RE: Re: RE: Re: RE: Dataviewer 3.1 live data streaming U
Mike,mikel wrote:We are looking into a hardware upgrade program right now.
Any idea as to when we might see the hardware upgrade program?
What will the logoistics of this upgrade be?
jg04lightning
RE: Re: RE: Re: RE: Re: RE: Dataviewer 3.1 live data streami
U7158, Lightning
Revision 9R02
2004 F150 Lightning
Mike any update on hardware upgrade??
Revision 9R02
2004 F150 Lightning
jg04lightning
U7158, Lightning
Revision 9R02
2004 F150 Lightning
Revision 9R02
2004 F150 Lightning
jg04lightning
U7158, Lightning
Revision 9R02
2004 F150 Lightning
Revision 9R02
2004 F150 Lightning
jg04lightning
U7158, Lightning
Revision 9R02
2004 F150 Lightning
Revision 9R02
2004 F150 Lightning
No news as of yet.
jg04lightning
U7158, Lightning
Revision 9R02
2004 F150 Lightning
Mike, please share your time line for this project.
Revision 9R02
2004 F150 Lightning
jg04lightning, due to the nature of our work we always have new "must do" updates and tasks needed that come out of nowhere. Because of this we cannot give definitive dates or ETA's on any of our stuff. Sucks but that is just the way it is. I have an 01 Lightning and JohnC has a Cobra. Trust me, we want it too.
Kevin@Diablo
Kevin@Diablo
jg04lightning
Kevin,
This sounds like a top down issue in the DiabloSport organization, but I am glad to see at least it is on your's and JohnC's want list as well. I will give it some time and if I have not seen any update threads, I will ping you just to let you know I am still interested in the upgrade program.
BTW, do you still have the stock bottom end in your 01 lightning?
Re: RE: Re: RE: Re: RE: Re: RE: Dataviewer 3.1 live data str
We are closer than ever to offering this upgrade program. Should not be too long now, couple weeks likely before it is implemented, and we will share full details of the program right here on the forum following a formal announcement.jg04lightning wrote:Kevin,
And to answer for Kev, yes, he still has a stock bottom end in the truck, running in the low 11's.
