Montess i need help asap!
RE: Montess i need help asap!
If I have 3 or more parameters selected, it says communicating, then fails. If I have 1 or 2 parameters selected it says comunicating, then shows 0's for the parameters selected. I have tried many combination of parameters when I do 2 or less, and the values logged are ALWAYS 0!
guys i have a similar problem.. save version of DV and DS Rev 9r04.. DV will communicate with tool just fine but when I try and log it fails imediately... Thanks
2004 Silverado 2500 4x4 6.0L
Torsion bar lift 2"
Bilstien Shocks
285/75/16 Cooper STT
DS Pred. U7193 Rev. 9r04
Torsion bar lift 2"
Bilstien Shocks
a-HA!!
a 7193 and DV 3.1.8.2. compatibility issue????? interesting...
can't be just the specific revision, cuz Redgto04 initially had the same problem with the 9r01 revision...
i cant say did not try with other version.. do you have John's ear, maybe he can shed some light....
Torsion bar lift 2"
Bilstien Shocks
Torsion bar lift 2"
Bilstien Shocks
We've reproduced the problem in-house. The fix will take some investigation.
johnc <at> diablosport.com
hey just a tht.. maybe john could answer... if my baud rate was not set to 115200 could that possibly cause the issue? just went and check baud and it was set at lower speed.. i will try the higher on way home..
Torsion bar lift 2"
Bilstien Shocks
Torsion bar lift 2"
Bilstien Shocks
thks john we must have been typing at same time...
Torsion bar lift 2"
Bilstien Shocks
Torsion bar lift 2"
Bilstien Shocks
see, you're not losing your mind Red!!
That is a very GOOD thing!
Just following up...
Torsion bar lift 2"
Bilstien Shocks
Torsion bar lift 2"
Bilstien Shocks
Have to be patient.......I hope they get a updated dataviewer asap...and I'm sure they will!
Grumpy_Aero_Guy
Well, looks like I'm not the ONLY one that discovers hidden gremlins in my software, here and there, with a new tool/firmware release.
I feel a little better.
DSLogRedux.com
DSLogRedux.com
I worked on this some on Friday, made some progress but did not get to a point where I could release. I believe that this will only require a DataViewer release, which is good news because the DataViewer does not require an extensive test period like a Predator CROM release would.
