need help fast!!!!!!!!!!!
cgray
Post by cgray »
file is missing or currupt i followed the instructions on the downloader but nothing happens. help me please. thanks in advance
2007 GMC Sierra Vmax 6.0 3" magnaflow ehxaust, K&N CAI, Predator U7194
johnc
RE: need help fast!!!!!!!!!!!
Post by johnc »
More Info Here
What, specifically, are your symptoms?
johnc <at> diablosport.com
cgray
Post by cgray »
i got the predator working but now the e-brake light and the abs light comes on just installed the latest update can i go back to an previous revisions
CANUCKPREDATOR
Post by CANUCKPREDATOR »
Whatever revision your Predator came with, you can't go back beyond that.
Did you change tire size? GM only allows a certain percentage of tire size change.
when you first got your predator, what revision came on it?
if it was an 8rXX revision, yes you can go back to whatever revision you want to...
if it came with a 9rXX revision already on it, you can only go back to other 9rXX revisions.
cgray
Post by cgray »
thanks for all te help my programmer is about an year old and i have various updates i was just making sure i could go back to one of the previous. as for the tire size im all stock it is a 2 wheel drive. i had just updated to 9r05 when the luight started to show.i was running 9r03 and everythging was just fine.
yeah, you can go back to 9r03... that will work...
CANUCKPREDATOR
don't forget to restore factory tune, downgrade to r03, then retune. write down your adjustments that you have made, that way you can put them back in when all is down.
Return to “Predator GM Gas”
