U7193 9r04 logging to laptop
swillia2
Post by swillia2 »
Guys, I have version 3.1.8.2 of Dviewer.. When I try and log with my laptop it connects just fine to the tool, but when I choose my param. and click record it fails.. I have tried leaving default selection all the way down to just one selection and nothing seems to make a difference.. Any help would be great..
2004 Silverado 2500 4x4 6.0L
Torsion bar lift 2"
Bilstien Shocks
285/75/16 Cooper STT
DS Pred. U7193 Rev. 9r04
swillia2
RE: U7193 9r04 logging to laptop
Post by swillia2 »
bump.. is anyone out thr able to log with laptop and DV 3.1.8.2 and U7193 9r04?
Torsion bar lift 2"
Bilstien Shocks
johnc
Post by johnc »
No need to track this issue in more than one thread. See here
johnc <at> diablosport.com
swillia2
Post by swillia2 »
yup gotcha.. i started this one and did not realize the other was same issue.. thks
Torsion bar lift 2"
Bilstien Shocks
johnc
Post by johnc »
This should be fixed. Please download the latest release.
swillia2
Post by swillia2 »
john that is great.. thks i will download today and test.. thanks again for quick response.. GREAT CUSTOMER SERVICE!!!
Torsion bar lift 2"
Bilstien Shocks
johnc
Post by johnc »
No problem. I am surprised that this issue was not caught in-house ages ago.
swillia2
Post by swillia2 »
ya i guess with the new found U7913 logging to laptop for AFR/WOT it is becoming a hot item.. smile...
Torsion bar lift 2"
Bilstien Shocks
swillia2
Post by swillia2 »
John, looks good.. I downloaded latest version and logged successfully with laptop.. One question for you, what is the "Knock Retard" name when hooked up to dataviewer? When I log it with Handheld it shows up under "missfire" as "Knock Retard (deg)) but when I hook up to laptop I do not see that as an option? Thanks
Torsion bar lift 2"
Bilstien Shocks
Redgto04
Post by Redgto04 »
On my handheld its "maximum knock retard" or something to that effect.............Do u not have this?
CANUCKPREDATOR
Post by CANUCKPREDATOR »
Total Spark Knock Retard
swillia2
Post by swillia2 »
nope guys i dont have either option when connected to laptop and dataviewer... red do you have maximum kr when connected to laptop or when using the handheld for logging?
Torsion bar lift 2"
Bilstien Shocks
I KNOW you won't have total knock spark retard as Canuck indicated, cuz that's only available for newer ECM's...
look at the parameters you DO have for knock retard (KR)...
list them here and I'll tell ya what to monitor...
swillia2
Post by swillia2 »
CPM Retard? this is the only one that i see with % deg not count.. I tried to log this one but did not get any hits, just 0%.. not sure what that one is? I have max kr on the handheld but I dont see the same on laptop.. Thanks
Torsion bar lift 2"
Bilstien Shocks
Redgto04
Post by Redgto04 »
Under pid's, misfire folder, Knock retard!
ScreenHunter_01 Sep. 02 21.58.gif (16.13 KiB) Viewed 3475 times
Return to “Predator GM Gas”
