2008 cummins power puck????
sdogre
Post by sdogre »
I am interested in some info on the power puck for the 08 6.7l cummins, i am wondering if you have to shim the fuel relief valve like with other units( IE ts mp-8) I also use a edge juice with attitude and wonder how this stack combo would work out, any input would be appreciated, Thanks Sean
RE: 2008 cummins power puck????
Yes, the Cummins applications require you to shim the fuel relief valve as well.
sdogre
Post by sdogre »
is this included with the power puck?
sdogre
Post by sdogre »
Still wondering if the shim kit comes with the power puck and if it will work with the edge juice with attitude, have been told by a couple people it will not work?
I cant say if it will work with the edge, not something we have tested.
It does however include the shim kit, yes.
sdogre
Post by sdogre »
does it raise fuel rail pressure or just manipulate map sensor readings on the cummins?
sohfast94
Post by sohfast94 »
Both since you have to install the shim kit. Not past acceptable limits however...
Insert Clever comment here...
