U7193 9r04 logging to laptop
NICE!!!
Thanks Red!!
swillia2
Post by swillia2 »
nope dont get that one with my vehicle... strange.. now was that from letting dataviewer pull in list or was that from opening a log that you capture on the handheld? because i do get that as an option when i view a log that i captured using handheld, but not an option when i use dataviewer control handheld.. thanks.. maybe its different with diff. vehicles? not sure..
2004 Silverado 2500 4x4 6.0L
Torsion bar lift 2"
Bilstien Shocks
285/75/16 Cooper STT
DS Pred. U7193 Rev. 9r04
Redgto04
Post by Redgto04 »
Thats logging to laptop with dataviewer!
swillia2
Post by swillia2 »
huh.. thats strange... i wonder if vehicle matters? thats the only thing i think is diff.. if i rem. correctly u are using u7193 9r04 and I assume you are using the latest DS VIEWER... so dif vehicle is the only thing i can think of.. Maybe John or someone with a 2004 2500hd truck could tell me what I am missing? thanks
Torsion bar lift 2"
Bilstien Shocks
yes, year of vehicles and their associated parameters that are available do matter...
not all vehicles have the exact same parameters available...
swillia2
Post by swillia2 »
i really think it is missing on my vehicle with DS Viewer... Unless they gave it some name that is not obvious, do you know what that CPM Retard might be? That is the only one that is marked with (deg) like KR on the handheld.. i dont guess it that big a deal i will just monitor with handheld for kr.. I am just happy they got the AFR working.. by the way lew got the PE set at WOT and it is running very strong... DIABLEW!!!
Torsion bar lift 2"
Bilstien Shocks
johnc
Post by johnc »
If that does not answer the question, please email me your log and I will take a look.
johnc <at> diablosport.com
swillia2
Post by swillia2 »
Thanks John.... Are you asking me to do a log with all parameters checked?
Torsion bar lift 2"
Bilstien Shocks
johnc
Re: RE: U7193 9r04 logging to laptop
Post by johnc »
swillia2 wrote:One question for you, what is the "Knock Retard" name when hooked up to dataviewer? When I log it with Handheld it shows up under "missfire" as "Knock Retard (deg)) but when I hook up to laptop I do not see that as an option? Thanks
This is the question I was referring to. If you still need an answer, then all I need is a log with this parameter in it.
swillia2
Knock Retard vairable logging with DataViewer
Post by swillia2 »
John, here is a .CSV file that has the KR entry from the handheld.. Let me know if you need the acutall .LOG file and I can get you one.. I just did not have one on my laptop at the moment. I can get you one tonight.. If you need something else just let me know.. It would be nice to be able to log with DataViewer, and get WOT/AFR and KR.. Thanks for your help..
Torsion bar lift 2"
Bilstien Shocks
johnc
RE: Knock Retard vairable logging with DataViewer
Post by johnc »
I do indeed need the .log file.
