po121 after ported throttle body and manifold
supercatxr7
I'm getting a po121 code after I had my throttle body ported. Anybody familar with this and can diablo fix the code through custom tuning?
2006 Monte Carlo SS 5.3 V8
U7191
U7191
RE: po121 after ported throttle body and manifold
A P0121 code is for the Throttle Position Sensor/Switch A Circ Range/Perf....
definitely does not sound like a tuning issue...
sounds like something's up with the throttle body / sensor after the work you had done to it...
supercatxr7
Yes, but I was looking at other forums on LS1 tech and it is a common problem with ported t bodies on LS motors. Most were able to tune it out by adjusting the MinMAP to 0 and the MaxMap to 100. Maybe some of the tuners have experienced this or tuned it out?
U7191
U7191
Email me a copy of your current tune and we'll check it out.
here's how to get your tune file outta your car Super... if ya don't remember from last time when I tweaked your tune.. heh..
http://diablosport.com/index.php?name=P ... pic&t=6547
supercatxr7
Yep, of course I remember! I just emailed the tune to both of you. Thanks!
U7191
U7191
Hey Lew, wanna take a crack at this one?
sickREDsierra
the problem is clearly the Monte Carlo. it isnt meant to be a performance car.
JFWY
JFWY
2007 Sierra, 370 C.I. , Custom CompCam, ProEdge 3600 converter, 4.11's with eaton LSD, Foose 20's, DynoTune Nitrous, Patriot CNC'd heads
supercatxr7
13.4's @ 104 with a few bolt ons, I don't think I'm doing too bad besides being wrong wheel drive!
U7191
U7191
supercatxr7
Just an FYI, I put an unported throttle body back on it and it is fine. Seems porting the tbody requires additional tuning to account for the range of the tbody at idle and such. Let me know if you guys can do anything with the tune to compensate for this, as I would really like to use the ported tbody with my ported manifold.
thanks!
thanks!
U7191
U7191
Re: RE: po121 after ported throttle body and manifold
I didn't get your tune/email man...supercatxr7 wrote:Yep, of course I remember! I just emailed the tune to both of you. Thanks!
sickREDsierra
thats VERY good actually..supercatxr7 wrote:13.4's @ 104 with a few bolt ons, I don't think I'm doing too bad besides being wrong wheel drive!
i only said that to mess with Lew. i know those cars are pretty quick.
Sure...mikel wrote:Hey Lew, wanna take a crack at this one?
Supercatrx7 - you've got mail!!
RE: Re: RE: po121 after ported throttle body and manifold
supercatxr7
Got the tune and loaded it, thanks. Code is gone, but shifting still isn't right. The shift points on light acceleration are still affected. Car pretty much starts out in first and shifts quickly to second and third on light acceleration from a stop. WOT is okay though.
U7191
U7191
