marcoengineering wrote:Andy knows his stuff pretty well. There is inherant risk with any type of tune use, I have this FlexFuel tune in my truck and have no qualms with using it. GM uses the same injectors on the 8.1L gas, which is 30% bigger than the 6.0L, so if the same injector can handle the 8.1L then it can handle more flow when needed. BUT if you were to start modifying the engine beyond stock configuration(hardware performance parts), then you would need to look into bigger injectors(even without the flexfuel tune), otherwise the "stock" injectors should work just fine in a stock motor/FlexFuel combination. Everyone has an opinion on this, but those links MikeL provided shows hardware data/parts, not just well maybe if worst case thinking, not to say the opinion of others isn't valid, but if you were really worried about your motor(or durability of your whole vehicle) you wouldn't mess with the stock OEM tune to begin with. This is just another option(like the 87 Tune or 91/93 Tune or the Custom Tune), and personally I like to have it even if I just get the 10%-15% better 100% gas MPG that teh FlexFuel tune gives.
MarcoEngineering
MarcoEngineering
So how do u like running E85? How is it powerwise, mpg before after? Are u saving money running it? This maybe a question for the diablo guys, but If I have a E85 tune done, first which tune would they want to modify (Stock, Diablo, Diablo modified)? I am also assuming LTFT's would have to be relogged/adjusted? Thats not a big deal....just curious! I can save my current tune right, and then have the E85 tune.....Just incase I need to switch back? I am very interested in this! Thanks for the help guys!
