i can't tune my car
MO
i can't tune my car
Post by MO »
i have ford mustang GT 2004
i try to tune it but
it shows that i have to update " your car is not updated pls contract your dealer for free update"
how can i update ? :(
RE: i can
Please post the software revision on the Predator and the calibration ID. The revision is found on the top line of the tool when booted up, (Predator version 7rXX). The calid is obtained by going to :
Options
Troubleshooting
Show calid
MO
RE: i can
Post by MO »
Hi Mike ....
software revision on the predator is 7r50d , and CALID is 'FBFG2TD'
my predator no. 143962 , U7146
johan
RE: i can
Post by johan »
On a side note, have you checked to make sure your vehicle does not have a chip in it? The ecu is located on the passenger side, right foot well behind plastic cover, you can remove cover and look at the ecu, if one end has tape or something sticking out of it(like a chip), i would remove it (with ignition off) and then try predator again. If the ecu has a little black plastic piece covering a hole then it is most likely not tampered with.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Return to “Predator Ford Gas”
