OUT OF MEMORY PROBLEM
lazorrazor
Post by lazorrazor »
(mikel wrote:
Looks like there may be a memory issue with these older Predators using this new crom, as it is larger than others of the past.
Eventually we will be redoing this entire tool as far as how it works, and it will free up memory for the logging.
Thanks)
2004 Mustang GT 4.6
u7146
9r03
Part#195333
A few weeks ago I posted an "OUT OF MEMORY" thread on this forum. I was given the above answer from Mike (in red) I tried fixing the problem using the method given over the phone by Brian (Go to OPTIONS/TROUBLESHOOT/LIVE DATA RESET) with no results. When will the tuner be redone as mentioned above so I can start using ALL of the advertised functions? Thank you
LaZoRRaZoR
RE: OUT OF MEMORY PROBLEM
Thanks!
bullitt005
Post by bullitt005 »
im goin to try that now to see if it gets fix .
thanks
40thmustang
Post by 40thmustang »
I have tried this after talking on the phone with them and won;t work for me either. How much longer until the problem is resolved and there is a new update?
Re: RE: OUT OF MEMORY PROBLEM
40thmustang wrote:I have tried this after talking on the phone with them and won;t work for me either. How much longer until the problem is resolved and there is a new update?
New update is being developed now.
40thmustang
So what is the estimated date of the new revision being released??
40thmustang
could I get an answer? I am pressured with time and this not being answered is not helping!!! Figures I blow the money to buy tuner and intereface kit to have it not work, then not have an update for months...
RE: Re: RE: OUT OF MEMORY PROBLEM
Looking at 2-3 weeks from now.
mrmustangman357
Post by mrmustangman357 »
Mike, you released a new update but it still doesn't solve any of the shortcomings discussed above.
Everyone who owns this tool is asking the question: Will the advertised features of this tool ever be fixed so we can use them?
The new update still has datalog problems, still can't live stream, and still can't function properly. when is this going to be addressed (if at all)?
not to sound harsh, but many people like me are having these same questions
mrmustangman357 wrote:Mike, you released a new update but it still doesn't solve any of the shortcomings discussed above.
OK, so, lets try this one.....
u7146_mustang-9r05.crom
(734.3 KiB) Downloaded 166 times
mrmustangman357
I just installed the crom. it seems my long term fuel trims are now working, but functionally I dont see any difference between this and the 9r04. can you elaborate on the changes?
mrmustangman357 wrote:I just installed the crom. it seems my long term fuel trims are now working, but functionally I dont see any difference between this and the 9r04. can you elaborate on the changes?
Added support for previously unsupported calibrations, fixed adjustable params that were not working (tire/gear), updated many of the tunes, and created a new method of identifying the vehicles to free up some memory for the logging issues.
workmangc
Post by workmangc »
All, I had problems with this .crom. I would keep getting a corrupt file error. After speaking to tech support we reinstalled an older .crom to get the tuner working again. I would hold up on installing this untill they confirm it's good to go.
Hmmm...looks like it worked for mrmustang357, and I just tested it on a tool here in the shop and it worked fine...
workmangc
Post by workmangc »
I wonder what that's all about.....
Return to “Predator Ford Gas”
