Whats ALL the parimiters that can be read LIVE on the U7198?
LS1C5VETTE
Post by LS1C5VETTE »
Can I read my A/F ratio while the car is running? Whats everything else I can read, I can find it in a search...
2000 M6 Corvette Coupe
RE: Whats ALL the parimiters that can be read LIVE on the U7
Do you have a Predator?
If so, plug it in and see for yourself.
There are alot of parameters that you can see, but A/F ratio is not one of them as the PCM does not monitor A/F.
You can see all 4 O2 sensors, the long and short term fuel trims, engine rpm, vehicle speed, etc.
camaross
Post by camaross »
you will need a aftermarket wideband O2 System to monitor this.
Return to “Predator GM Gas”
