TUNE DATA AVAILABLE?
atsugidad
Post by atsugidad »
U7198
Ver 2.13
2002 Vette Coupe
Is there a chart available that shows the Adjustable TUNE parameters for the Stock Tune vs the Performance tune in this model Predator? Would like to know so I can adjust things having some idea where I'm going with it.
Phil
RE: TUNE DATA AVAILABLE?
Timing Table 1000-1800rpm (+/- 20%)
Timing Table 2000-4000rpm (+/- 20%)
Timing Table 4000-7000rpm (+/- 20%)
Fuel Table 2000-4000rpm (+/- 20%)
Fuel Table 4000-7000rpm (+/- 20%)
Idle (+ 500rpm / -300rpm)
Speed Limiters (Trucks Only)
Rev Limiters
RPM Shift Points
MPH Up and Downshifts
Shift Timing
Shift Pressure
Cooling Fan ON and OFF temperatures
Re-Calibrate Speedometer for Gear and Tire Size Changes
Torque Management abuse mode time limit ON/OFF
% torque reduction vs. RPM ON/OFF
Upshift torque reduction (all gears) ON/OFF
Adjust for different injector size
Adjust COT enable temperature
atsugidad
Post by atsugidad »
Sorry, Looking for actual specifics.
U7198
Ver 2.13
2002 Corvette Coupe
1. What are the ACTUAL SETTINGS USED (numbers entered) in STOCK TUNE - 2002 Corvette C5 - (NON Z06)
2. What are the ACTUAL SETTINGS USED In the Performance Tune that come installed in the U7198 Ver 2.13 For the 02 CORVETTE Coupe - NON Z06
I Want to know what deviations or changes are made for each parameter from Stock to Performance.
Example could be:
Timing set at XX in Stock tune and at YY when the Perf Tune is installed
hahaha... many have asked in the past... ya won't get that info from them...
why would they publish their tune info for their competitors??? heh...
You can log the stock tune and then the performance tune and see the changes...
atsugidad
Post by atsugidad »
Guess your right. Can't fault a guy for asking.
nope.. no harm no foul... heh ;)
Return to “General Support”
