Gear ratio change in the factory hp tune?
I have a "01" Mustang GT (U7146) and was wondering if I could modify the gear ratio in the "factory HP tune"?, I never updated to the latest revision if there is one. Last time I checked i can only modify the gear ratio in the 93 octane diablo tune. I just want to be sure before I do any further modds. Thanks!
RE: Gear ratio change in the factory hp tune?
Yes, this will work, but you should update to the latest revision as it may not work in an older revision.
OK, heres the trick.
Install the tune to your car with 7r50d with the rear o2s turned off.
Now, go in and do a read extra tune, then export the extra tune from the Pred to the PC.
Then restore your backup.
Now, update to 9r05, install the tune you exported as a custom tune, then modify that tune for the gear change, all set.
Wow! Im so behind when it comes to technical stuff, I never hook-up my predator to my pc nor do i have the equipment(wires) to do so. To be honest I have a pair of MILS I still use so I don't have to go the the predator to mess with 02 sensors. Also I love the 93 diablo tune so if I get gears I'll probably stick with the 93 diablo tune anyways. One more question, if I have 373's gears and for some reason I have to go to the ford delearship for service and I reinstall my original factory tune would the only thing that would be off is my speedo? Would my car have a driviability issues(PCM woe's) with the steeper gears and original factory tune besides the speedo being off? My car is a 5-speed.Thanks, Im gonna try to become more computer savy the the predator
Speedo being off will be the only problem in that case, yes.
v6procharged
