Default GM Dashboard?
Smitty'sGTO
Post by Smitty'sGTO »
slp7190
V.9r01
2005 GTO
I recorded several logs on a laptop this weekend using the default GM dashboard, and also choose additional PID's, but I never able to get the correct PID's logged to use DSLOGREDUX.
I finally gave up and just logged to the Predator. It seems like some of the PID's in the default GM dashboard did not record.
One log has the Accelerator Position checked and shows in the dashboard, but the value remains 0 (zero). Of course, DSLOGREDUX did not work on this log.
Any suggestions for me to make sure that I am logging the needed parameters, I think I about have my LTFT's just about dialed in, but would like to be able to log more data than the Predator can.
RE: Default GM Dashboard?
log Commanded Throttle Position
johnc
Post by johnc »
Download a log from the Predator that you know works, load it into the DataViewer, then save this as a new dashboard, named "DS Log Redux" or whatever. This way you know when you are live streaming you always have the parameters you need.
johnc <at> diablosport.com
Smitty'sGTO
Thanks 06MonteSS, that helps. I will also attempt to save the dashboard, my problem is I am not choosing the correct PID's when using the laptop. I will figure it out, thanks again for the tips. Great product, it's the user who needs development. :D
Return to “DataViewer/DV2”
