boost pressure with live data on pred.
jivemother
Post by jivemother »
when i am using the the live data on the pred. it shows 14 lbs at an idle .
that cant be right .then when i hog on it down the road it hits 50 lbs on a stock turbo!!!!!! what should it be at idle ? i thought like 0 or 1-5 lbs at most..
03 ram 4x4
power puck
predator
RE: boost pressure with live data on pred.
My guess is that at idle you are seeing about 14.7 psi, which is atmospheric pressure, then when you see 50 at WOT, it is actually 50-14.7 to see the boost being added by the turbo, so about 35 lbs.
jivemother
ya thats what i was thinkin thanks for the snappy responce
03 ram 4x4
power puck
predator
