05 silverado WOT 1-2 shift
racerx55
Post by racerx55 »
With the stock tune, the WOT 1-2 shift actually seems quicker than with adjusting the pressure and things up. It seems to kinda slide into 2nd more than just hit hard and shift. Part throttle is great. anyone else notice this? or maybe my trans is just beat to hell already.
93 Talon Tsi AWD - 10.89@128 - 28 psi ECM link
93 Laser RS AWD - 12.97 @ 104
91 Talon dirt circle track car
05 Silverado Z71 HO 5.3 "B" - predator U7193
fiero429
RE: 05 silverado WOT 1-2 shift
Post by fiero429 »
I have notice the same thing on my truck GMC Sierra Denali 2004
Re: 05 silverado WOT 1-2 shift
racerx55 wrote:With the stock tune, the WOT 1-2 shift actually seems quicker than with adjusting the pressure and things up. It seems to kinda slide into 2nd more than just hit hard and shift. Part throttle is great. anyone else notice this? or maybe my trans is just beat to hell already.
What revision is on your Predator?
racerx55
Post by racerx55 »
I just updated it to the newest version yesterday. 9r06.
i had not used it with the older 9r05 software. The stock 1-2 shift is by far softer but its quicker to hit the gear, where the preset tune or adjusting it up seems to make it slide in when the TQ management puts power back on the trans is still slipping into gear. 4L60E is not that great of a trans to begin with so im blaming that for now. they are a POS.
Almost seems like a longer Tq reduction time would help the discs in the trans have time to grab ahold. Would adjusting the shift time slower hold the TQ reduction longer?
The reduction of TM should not cause tranny slippage, it is most likely a weak tranny, as we have been using these same tunes in the trucks for years with no adverse affects.
I'd suggest having the tranny serviced with at least a fluid and filter change to see if it gets better.
racerx55
Post by racerx55 »
yea like i said the 4L60E is a POS trasnsmission. i want to change to a 4L80 before too long but need to research what i gotta to for the TCM and all that garbage.
