My Predator is Unable to Connect to PC!!
s_alnejadi
Post by s_alnejadi »
I tried to connect the Predator to my Laptop .. Using 9pin Male to USB port and it wouldn't work with me .. Is it possible to do this connection? because i don't have a 9pin Female in My laptop! .. The Predator Screen shows (XMODEM TIMEOUT) in PC Comm. Screen! So Plzz Help .. I Downloaded The Predator Interface and the program worked with me but is seems that there is a communication problem .. ThanX
RE: My Predator is Unable to Connect to PC!!
It sounds like you did not install the driver for the USB cable.
You will need to run this disc in your PC before the cable will work.
Return to “Predator GM Gas”
