AFR with procharger
AFR with procharger
hi i have 05 mustang gt with P-1SC-1 procharger ,long tube headers and cat back + i have perdator with procharger custom tune it comes with the procharger
i have problem with the fuel @ wot it's too lean i want to known the AFR @wot so i can adjust the fuel table
i can't reach 10psi only 8psi
yukon denali 6.2 with k&n air intake sys+corsa exhaust sys+diablo tune
08 Corvette zo6 with k&n cai+corsa exhaust sys+diablo tune
09 mustang gt waiting for predator
RE: AFR with procharger
Did you put it on a dyno? Or do you have a wideband in the car? IF you could make me a datalog of advanced WOT until it leans out I'm sure I could troublshoot it for you... What's your setup? Doesn't the procharger only come with 8psi? You have a stock MAF?
Insert Clever comment here...
ok man i will send my dyno sheet tomorrow with the wot log
that's my dyno chart man sorry for delay
- mustang dyno.jpg (27.9 KiB) Viewed 3744 times
What is the dotted red line in the A/F chart?
Looks like they have it at 12:1 so it's definetly lean.mikel wrote:What is the dotted red line in the A/F chart?
http://www.tpctuning.com
Yeah, it looks like the reference line is 12:1, so it is actually running like 12.5:1....SCARY.tuningss wrote:Looks like they have it at 12:1 so it's definitely lean.mikel wrote:What is the dotted red line in the A/F chart?
I'd suggest not going WOT till you get this sorted out.
Mike
that's my tune man
- procharger tune.frg
- (6.25 KiB) Downloaded 181 times
There you go...
Should be right at 11.9-12.0 now...
- procharger_tune_2.frg
- (960.14 KiB) Downloaded 203 times
RE: There you go...
thanks man i'll try it and i'll let u know
