Black smoke at start up 08 Charger/Procharger 5.7 HEMI
08stonedcharger
Post by 08stonedcharger »
Hello guys, I installed a Procharger supercharger on Friday and everything is fine except when I start the car I get a little black smoke coming from the tail pipe. If I stop somewhere for a few minutes and try to start the car, it struggles a bit and then starts. The starter even stays engaged a bit longer untill the car starts. If I leave the car in the garage overnite, it starts fine but I stll get the black smoke. I called Procharger and they say they don't know why I would have these issues. Can the fuel injectors be adjusted at start up to spray less fuel? I beleive what is happening is I have residual fuel from shutting the car off and then as soon as I start the car the injectors spray again causing the issue. I had the car on a Dyno on Saturday and the mixtures were fine at all RPM ranges, even at idle. I'm at 3800 FASL and I don't know if the tune is set for this altitude, Procharger is at 1000 FASL.
Please help!!!
Thank you
Quick
RE: Black smoke at start up 08 Charger/Procharger 5.7 HEMI
Post by Quick »
I'm just guessing here... sounds like it's only doing that when the PCM is in warm up mode (and maybe startup mode)? I wonder if they changed anything in the tune for those modes. Or if that's just expected. I'm guessing it's the altitude. Both those modes are Open Loop and in Startup Mode the PCM is not looking at the narrow bands. It is looking at MAP though. Maybe if it wasn't adjusted for the altitude you're going to be running rich in that mode? Shouldn't be much of a problem if it's only during warmup. From the manual:
FUEL INJECTION
OPERATION
INJECTION SYSTEM
All engines used in this section have a sequential Multi-Port Electronic Fuel Injection system. The MPI system is
computer regulated and provides precise air/fuel ratios for all driving conditions. The Powertrain Control Module
(PCM) operates the fuel injection system.
The PCM regulates:
• Ignition timing
• Air/fuel ratio
• Emission control devices
• Cooling fan
• Charging system
• Idle speed
• Vehicle speed control
Various sensors provide the inputs necessary for the PCM to correctly operate these systems. In addition to the
sensors, various switches also provide inputs to the PCM.
The PCM can adapt its programming to meet changing operating conditions.
Fuel is injected into the intake port above the intake valve in precise metered amounts through electrically operated
injectors. The PCM fires the injectors in a specific sequence. Under most operating conditions, the PCM maintains
an air fuel ratio of 14.7 parts air to 1 part fuel by constantly adjusting injector pulse width. Injector pulse width is the
length of time the injector is open.
The PCM adjusts injector pulse width by opening and closing the ground path to the injector. Engine RPM (speed)
and manifold absolute pressure (air density) are the primary inputs that determine injector pulse width.
MODES OF OPERATION
As input signals to the PCM change, the PCM adjusts its response to output devices. For example, the PCM must
calculate a different injector pulse width and ignition timing for idle than it does for Wide Open Throttle (WOT).
There are several different modes of operation that determine how the PCM responds to the various input signals.
There are two different areas of operation, OPEN LOOP and CLOSED LOOP.
During OPEN LOOP modes the PCM receives input signals and responds according to preset PCM programming.
Inputs from the upstream and downstream heated oxygen sensors are not monitored during OPEN LOOP modes,
except for heated oxygen sensor diagnostics (they are checked for shorted conditions at all times).
During CLOSED LOOP modes the PCM monitors the inputs from the upstream and downstream heated oxygen
sensors. The upstream heated oxygen sensor input tells the PCM if the calculated injector pulse width resulted in
the ideal air-fuel ratio of 14.7 to one. By monitoring the exhaust oxygen content through the upstream heated oxygen
sensor, the PCM can fine tune injector pulse width. Fine tuning injector pulse width allows the PCM to achieve
optimum fuel economy combined with low emissions.
For the PCM to enter CLOSED LOOP operation, the following must occur:
1. Engine coolant temperature must be over 35°F.
• If the coolant is over 35°F the PCM will wait 38 seconds.
• If the coolant is over 50°F the PCM will wait 15 seconds.
• If the coolant is over 167°F the PCM will wait 3 seconds.
2. For other temperatures the PCM will interpolate the correct waiting time.
3. O2 sensor must read either greater than 0.745 volts or less than 0.29 volt.
4. The multi-port fuel injection systems has the following modes of operation:
• Ignition switch ON (Zero RPM)
• Engine start-up
• Engine warm-up
• Cruise
• Idle
• Acceleration
• Deceleration
• Wide Open Throttle
• Ignition switch OFF
5. The engine start-up (crank), engine warm-up, deceleration with fuel shutoff and wide open throttle modes are
OPEN LOOP modes. Under most operating conditions, the acceleration, deceleration (with A/C on), idle and
cruise modes, with the engine at operating temperature are CLOSED LOOP modes.
IGNITION SWITCH ON (ZERO RPM) MODE
When the ignition switch activates the fuel injection system, the following actions occur:
• The PCM monitors the engine coolant temperature sensor and throttle position sensor input. The PCM determines basic fuel injector pulse width from this input.
• The PCM determines atmospheric air pressure from the MAP sensor input to modify injector pulse width.
When the key is in the ON position and the engine is not running (zero rpm), the Auto Shutdown (ASD) and fuel
pump relays de-energize after approximately 1 second. Therefore, battery voltage is not supplied to the fuel pump,
ignition coil, fuel injectors and heated oxygen sensors.
ENGINE START-UP MODE
This is an OPEN LOOP mode. If the vehicle is in park or neutral (automatic transaxles) or the clutch pedal is
depressed (manual transaxles) the ignition switch energizes the starter relay when the engine is not running. The
following actions occur when the starter motor is engaged.
• If the PCM receives the camshaft position sensor and crankshaft position sensor signals, it energizes the Auto
Shutdown (ASD) relay and fuel pump relay. If the PCM does not receive both signals within approximately one
second, it will not energize the ASD relay and fuel pump relay. The ASD and fuel pump relays supply battery
voltage to the fuel pump, fuel injectors, ignition coil, (EGR solenoid and PCV heater if equipped) and heated
oxygen sensors.
• The PCM energizes the injectors (on the 69° degree falling edge) for a calculated pulse width until it determines
crankshaft position from the camshaft position sensor and crankshaft position sensor signals. The PCM
determines crankshaft position within 1 engine revolution.
• After determining crankshaft position, the PCM begins energizing the injectors in sequence. It adjusts injector
pulse width and controls injector synchronization by turning the individual ground paths to the injectors On and
Off.
• When the engine idles within ±64 RPM of its target RPM, the PCM compares current MAP sensor value with
the atmospheric pressure value received during the Ignition Switch On (zero RPM) mode.
Once the ASD and fuel pump relays have been energized, the PCM determines injector pulse width based on the
following:
• MAP
• Engine RPM
• Battery voltage
• Engine coolant temperature
• Inlet/Intake air temperature (IAT)
• Throttle position
• The number of engine revolutions since cranking was initiated
During Start-up the PCM maintains ignition timing at 9° BTDC.
ENGINE WARM-UP MODE
This is an OPEN LOOP mode. The following inputs are received by the PCM:
• Manifold Absolute Pressure (MAP)
• Crankshaft position (engine speed)
• Camshaft position
• Knock sensor
• Throttle position
• A/C switch status
• Battery voltage
• Vehicle speed
• Speed control
• O2 sensors
The PCM adjusts injector pulse width and controls injector synchronization by turning the individual ground paths to
the injectors On and Off.
The PCM adjusts ignition timing and engine idle speed. Engine idle speed is adjusted through the idle air control
motor.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
johan
Post by johan »
Sounds to me like your crank fuel pw needs to be reduced, this can all be done via a custom tune. The stock crank pw will always need to be reduced with larger injectors.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
08stonedcharger
Re: RE: Black smoke at start up 08 Charger/Procharger 5.7 HE
johan wrote:Sounds to me like your crank fuel pw needs to be reduced, this can all be done via a custom tune. The stock crank pw will always need to be reduced with larger injectors.
Johan, is that something you guys can do for me if I send you the tune?
Joe
johan
RE: Re: RE: Black smoke at start up 08 Charger/Procharger 5.
Post by johan »
Should be able too yeah.
Diablosport INC
