WHATS WRONG???
WHATS WRONG???
after i installed my BBK CAI and 70mm throttle body and plenum my car started to sound like i was dragging cans under it when i would step on the gas pedal lightly and felt really sluggish on accelaration... after installing the predetor tune(U7146) it got louder, i dont know much about cars but that sound it makes doesnt seem right to me, can anybody tell me if there is anything wrong with my car, if so how do i fix it??? If you need more info please let me know!!!!
any input highly appreciated!!!!
thanks
thanks
carter242000
well i run 91 octane from chevron, im not getting any codes for detonation, is there any way for me to know if its runnig lean or not???? its my DD and the only way for me to get around!!!!! how do i fix it and fast, also what kind of damage to the engine are we talking about i mean is it REALLY BAD, i need to fix it as soon as possible so please help
2003 Mustang GT auto
Accufab 70mm TB and Plenum
BBK CAI
PP intake manifold
Flowmaster mufflers (no cats)
Diablo sport tune
Motive 3.90 gears
BBK CAI
PP intake manifold
Diablo sport tune
Motive 3.90 gears
carter242000
if it sounds like your shaking up a can of marbles then its definately detonation, and that will destroy your motor. you can have detonation without codes...i did. i would return everything to stock and see if its gone, if it is then you were prob. running lean. to check that you would need an air fuel ratio meter or have it put on a dyno. if cleaning the maf sensor and returning it to stock doesnt fix it I would definately have it towed to your mechanic.
carter242000
is that on all fender well CAI or just the ones with the MAF sensor after the bend, i was going to switch to a JLT CAI witch has the MAF befor the bend, its acually relocated in the fender well, would this help at all???
BTW thatnks for the replys
BBK CAI
PP intake manifold
Diablo sport tune
Motive 3.90 gears
BBK CAI
PP intake manifold
Diablo sport tune
Motive 3.90 gears
carter242000
should i go JLT CAI or JLT ram air intake??? As for the BBK one ill remove it tomorrow asap and put the stock one back, ill also clean the MAF and switch gas maybe even octane... ill invest in a wide band for the mean time to keep in eye on A/F ratio. can you tell me what kond of damage im looking at????
BBK CAI
PP intake manifold
Diablo sport tune
Motive 3.90 gears
BBK CAI
PP intake manifold
Diablo sport tune
Motive 3.90 gears
carter242000
carter242000
should i change the plugs as well... i got my GT about 4 months ago and changed the plugs day after i got it, so if its detonation should i replace those as well??
BBK CAI
PP intake manifold
Diablo sport tune
Motive 3.90 gears
BBK CAI
PP intake manifold
Diablo sport tune
Motive 3.90 gears
carter242000
ok thanks for the help ill update as soon as fix those things on the car and let you know if it worked or not
BTW thanks for the replys really helped alot!!! first time mustang owner so any more input on what works and what doesnt from who ever would be GREATLY appreciated!!!!
THANKS!!!!
THANKS!!!!
BBK CAI
PP intake manifold
Diablo sport tune
Motive 3.90 gears
BBK CAI
PP intake manifold
Diablo sport tune
Motive 3.90 gears
ok so heres wat i did... i removed my BBK CAI and reinstalled the factory air box, cleaned the MAF, removed the predetor tune and reinstalled the stock one, my gas tank was on its last drop so i pumped 86 octane into it to see if that might help, after all this NO CHANGE, that F****** sound is still there. i drove around for a while logging a couple of things with the predetor. i noiticed that the DEG SPRKADV would change a lot, when cruising without even touching the gas it would stay at 20 DEG, when i would accel a little it would jump up to 34-36 DEG, one time it went to like 46 or 56 cant quite remeber, i would let go of the gas pedal and it would rapidly drop back down to 20 DEG, and when i would floor it the DEG would drop down to like 10 or 12 DEG, i think the lowest was like 8 or 9... my question is, is this normal for any car??? also forgot to mention that i checked my plugs and they looked pretty bad, i wont be able to replace them until friday (PAY DAY), does this sound like detonation, will replacing the plugs fix my problem or would i have to do something else aswell???
if you need more info let me know
thanks
thanks
BBK CAI
PP intake manifold
Diablo sport tune
Motive 3.90 gears
BBK CAI
PP intake manifold
Diablo sport tune
Motive 3.90 gears
