datalogging questions 05 mustang gt u7140
grngt50
Post by grngt50 »
Hey everybody,
I just received my new Predator model u7140 for my 05 mustang gt and I have a few questions. I have an S&B cold air kit which is not supported by the Predator. Are there any canned CAI tunes that might work well with this CAI?
For the time being, I have loaded the 93 ocatane tune with the MAF curve adjusted 5% and have taking out 2 degrees timing global (I only have 91 octane available). This tune is working really well so far but I'd like to datalog and check to see how lean/rich I'm running. What sensors should I select in the datalog menu to be recorded to accomplish this? Sorry if this not making sense, I'm an old 5.0 guy and am completely new to these flash tuners and there amazing capabilities!
Any advice/tips are greatly appreciated!
-James
grngt50
RE: datalogging questions 05 mustang gt u7140
Post by grngt50 »
also...........would there be any benefit/power gain by switching intakes? Something like a jlt or a c&l? Or would the cost outweigh the horsepower gain?
Yes, the easy answer is that the JLT or C&L will likely make more power, as they are some of the best power making CAIs we have tested.
To use the S&B properly, will require a custom tune done either on a dyno or by extensive logging on the street to dial in the MAF curve for that intake since we have never flow tested one to develop a curve for it.
grngt50
Re: RE: datalogging questions 05 mustang gt u7140
Post by grngt50 »
mikel wrote:Yes, the easy answer is that the JLT or C&L will likely make more power, as they are some of the best power making CAIs we have tested.
ok that kinda answered my question..........what do I need to be looking for when I datalog on the street to help dial this in? MAF curve? WOT fuel? Knock sensors? Thanks again for the help!
grngt50
RE: Re: RE: datalogging questions 05 mustang gt u7140
Post by grngt50 »
can I get some help here?
kmac1
Re: RE: Re: RE: datalogging questions 05 mustang gt u7140
Post by kmac1 »
grngt50 wrote:can I get some help here?
I have a tune for the S&B cai going into the next revision of the U7140. You'll be able to load this update into your Predator for free as soon as it is available. Keep checking the downloads page periodically, it will be up soon.
Kevin@Diablo
grngt50
Post by grngt50 »
Kevin@Diablo
thank you very much!!!!
wburners
S & B intake
Post by wburners »
I also have an s & b cai on a 06 gt. I'm looking forward to the s & b tune. Do you know if I can download that tune when it comes out without getting the previous updates? I have never updated my tuner. I also have my maf curve at +5. Will I need to reset that paramater before i install the s & b tune?
grngt50
Re: S & B intake
Post by grngt50 »
wburners wrote:I also have an s & b cai on a 06 gt. I'm looking forward to the s & b tune. Do you know if I can download that tune when it comes out without getting the previous updates? I have never updated my tuner. I also have my maf curve at +5. Will I need to reset that paramater before i install the s & b tune?
The s&b tune will be on the latest revision, so you'll have to update in order to get the tune. Before you can update your tuner to the most current revision, you'll have to return the stock tune to your car. I think when I did this and went to reinstall my modified tune all of the parameters had been reset. But you'll want to make sure that the MAF curve is at the stock setting when you install the new s&b tune, otherwise your car would likely run rich and you wont get the full benefit of the custom tune
grngt50
RE: Re: S & B intake
Post by grngt50 »
Kevin,
Any update on when the new revision is due to be released?
Return to “Predator Ford Gas”
