Just re-flashed at Ford Dealer (returned to stock prior to drop-off,) new flash is supposed to help keep EGTvalves cleaner I think....anyway, my Tuner no longer works, and I got these two messages:
VXBC9N8.HEX*
TQBF0NA.HEX*
Calid ARZ2AL00 on 2004 F-250 6.0 Powerstroke
RE: Calid ARZ2AL00 on 2004 F-250 6.0 Powerstroke
What part number Predator do you have?
What revision is it on?
Green U7160 R 45 upgraded last spring. Do you need the 16 digit key?mikel wrote:What part number Predator do you have?
JM
This tools memory has been filled.
It will require a hardware upgrade to make it work again.
Give us a call and we can explain the details.
gatorbryan
Re: RE: Calid ARZ2AL00 on 2004 F-250 6.0 Powerstroke
I also have the U7160 with the same problem and revision. what do I have to do to get it to work? and is it going to cost more money? thanks, Bryanmikel wrote:This tools memory has been filled.
