Throwing code P0603 when installed
RE: Re: RE: Throwing code P0603 when installed
Just an update: Went out this morning; Started fine, but had that little surge as I was getting up to speed (like I had a little sense). Does not surge at all when I nail it. Also seemed to be louder on the lower end (clicking of the injectors?) Where did all my black smoke go? Not that I'm complaining, just never been able to see much behind me when I floor it.
2003 Ford Excursion 6.0L
S & B Intake, MBRP 4" Turbo Back exhaust, DiabloSport Predator U7165
Cal ID: VXAP2A2
I Might Be Slow But I'm Ahead of You
Cal ID: VXAP2A2
hahaha. Smoke doesn't mean it's going any faster.. Diesels can make good power and not smoke...You want some more? I can fix the surge I'll work on that now... Any other requests will I'm at it?
Insert Clever comment here...
Re: RE: Re: RE: Throwing code P0603 when installed
What do you mean smoke doesn't make it faster ? Next people will be saying that each piece of chrome doesn't add 25 hp. How can that be ?sohfast94 wrote:hahaha. Smoke doesn't mean it's going any faster.. Diesels can make good power and not smoke...You want some more? I can fix the surge I'll work on that now... Any other requests will I'm at it?
With no cloud how do you screw with those annoying weedeater motored cars that think they are fast simply because they are loud.
Just kidding, I was floored when I stepped on it and there was no giant puff of smoke. Your products ROCK. Simply awesome !!
Cal ID: VXAP2A2
Cal ID: VXAP2A2
RE: Re: RE: Re: RE: Throwing code P0603 when installed
Now just to figure out your surge... About what rpm was this?
I think it was botween 1200 and 1400 rpms, but I would have to get it to repeat to be sure.
Cal ID: VXAP2A2
Cal ID: VXAP2A2
Try this.
- grumpy_vxap2a2.frg
- (153.52 KiB) Downloaded 240 times
Did the same. The surging is between 1500 and 2000 rpms. For the time being I have restored v.9r05 until I can get a little more time to play with it. It still threw the P0603 after install. Reset and seemed OK. will see later this afternoon. Before dealer flash, did not throw code. And does not seem to return after cleared, is this just a "side effect" of tuning?
Cal ID: VXAP2A2
Cal ID: VXAP2A2
OK. Found time to try one more time. As I stated before, I went ahead and restored the truck to v.9r05
The P0603 seems to only be thrown when installing a new tune. It does continue to throw P2290 Injector control pressure too low. the surge seems to be around 1750-2000 rpms when slowly accelerating. Also, The truck develops a strange surge at 55 mph in top gear (I believe I just need to have the tranny flushed to resolve this one) Cal ID: VXAP2A2 Sn: 9000946 2003 Ford Excursion 6.0 If my brain sparks and I can think of anything else, I'll post up.
Thanks for being patient with this, your customer service is excellent.
Diablo Sport Rocks
Diablo Sport Rocks
Cal ID: VXAP2A2
Cal ID: VXAP2A2
