tranny relearn?
tranny relearn?
hello there i just picked up a u7185 from our local auto parts dealer the unit appears unused, and loaded a tune into my truck just fine. but the box was opened so i'm not sure if i'm missing anything. just wonderinghow or where i can find the right process to properly relearn the tranny. i was told from another site that the process could be found on diablos site but i cant find it , anyone help me out ...
RE: tranny relearn?
People have posted the tranny relearn procedure here, but it is not done with the Predator.
Do a search to find the post if you need it.
bwheatley5
transmission kicks out and down a gear
hey there,
i got a 2004 lb7 duramax. i got a u7180 programmer. and i would set the tune at 65 and i would go down the road not pinned up, but pickin up speed and once i get to 80 mph and about 3 grand it kicks me out of that gear and wont downshift. it says on the msg "range shift perhibeted" the thing is im not being hard on the tranny i can go faster in stock. please help
RE: transmission kicks out and down a gear
Does it always do this?
Are there any codes when this happens?
bwheatley5
tranny
it does it when i try to go fast and it kicks me out of that gear and wont down shift and the engine light comes on. then i go diagnostics on the ds and it says po102 mass air flow circuit, low input. and po112 intake air temp circuit, low input?
bwheatley5
Don't you do the samething in tow haul mode also.
http://www.thetruckstop.us
07 - CHEVY LBZ DURAMAX
All-Terrain T/A® KO - 295 75R16,
DYNOED ON 20 July 08 WITH -
PREDATOR SET ON THE 85HP TUNE / 423 RWHP - 709 FT/LBS
PREDATOR SET ON THE 120HP TUNE / 458 RWHP - 754 FT/LBS
bwheatley5
One way to speed up the trans relearn is to start from a stop in D, let it upshift to 5th or 6th(depending on trans), then put it in 1st and let it downshift until you come to a full stop, repeat this 2 more times.
And dont worry it will not downshift into 1st as soon as you put it in 1st it will shift down through the gears until you reach 1st.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
