7194 DOD help
Glassman
7194 DOD help
Post by Glassman »
Greetings
I have an 07 Tahoe vin "0" 5.3 L engine flex fuel.
I will be purchasing a 7194 in the near future...In reading the past posts on DOD I see where the code to turn off the DOD has been identified and can be turned off....my question is can the threshold for V4 operation be moved? I have a 33 mile flat road commute (florida) which would benefit if I could get the V4 mode to engage more often?
Question 2 since this feature is not on the current version...would this be a software change..or is this a hardware change requiring a new predator?
Thanks in advance
Bill
RE: 7194 DOD help
the DOD operation is not a user-adjustable parameter... it's either on or off, as set in the pre-defined included tunes.
To do what you're asking about, you'd have to talk to the guys at Diablo if it's even doable, and if it is, it would require a custom tune.
Return to “Predator GM Gas”
