2007 tahoe ?
lt1z350
2007 tahoe ?
Post by lt1z350 »
Have the u7194 and looking for more options. I have read that you are working on some stuff just wondering what will be next ( trans stuff I hope) and when. I had a 2003 tahoe prior to this and had done a custom tune on it with the same bolt ons and my 07 is a slug compared to the 03. Z71 to Z71 same options and bolt ons. I have tuner cat and the program stuff inst available for the 07 yet so I decided to try your programmer as I have heard it was the best out of what was available. Just used to being able to do it all with my tuner cat so looking forward to doing more with the tuner untill they come out with the bin file for the 2007. Also what do you think of using the 93 tune and pulling timing as my wife wont will only use 87 due to the cost right now. Cant wait untill e-85 hits Fl so we can enjoy the power benifits of the octaine boost. I had saw pretty good gains with turning off the tq mgt on the 03 and am suprized you didnt see good gains on the 07 stuff. My 03 went from not turning over the tires to doing a nice burn out with the tq mgt off. 3.73 in both so should anyway I would hope with around 300 hp. Look forward to more tuning and thanks for any time spent on replys.
RE: 2007 tahoe ?
TCM support will likely be the next big thing for this application.
Once that comes, you will have the ability to disable TM fully.
I would just use the 87 octane tune as there is more timing at part throttle in the 93 tune which you cant remove with the Predator.
