your vehicle is not in our database cal_id is RYAF2TZ
khalid80
Post by khalid80 »
Hi there
I have mustang gt 2002 m, my new diablo predator U7146 not working with my car as its shown mesg
your vehicle is not in our database. contact your dealer for a free update cal_id is RYAF2TZ
Please i need your help i am from United Arab Emirates (Dubai)
RE: your vehicle is not in our database cal_id is RYAF2TZ
Can you please tell me what revision is on your Predator now?
khalid80
Post by khalid80 »
thanks for your reply
Its new device, sorry bro what do you mean by revision and from where can i get it?
Top line of the main menu when the tool is powered up.
khalid80
Post by khalid80 »
Predator V.9r05
I have a feeling that this is an odd export calibration as we have no record of that calibration from Ford.
khalid80
Post by khalid80 »
So what can i do i like your device any suggestions
do i need to change the device or should i change the car ECU if so which one will be ok with your device.
The only suggestion I can come up with would be to see if you can get a dealer to update the PCM to see if it will change the calibration to one that we currently support.
khalid80
Post by khalid80 »
i dont think the dealer here will do such things
svo90
Post by svo90 »
i'm having the same problem as you are i just bought mine yesterday what do we need to do???
kmac1
Post by kmac1 »
Guys, hang on to your Predators. I have the tunes made for these calids but they need to be added to the tool. We'll be making a revision very shortly, I am just trying to fix a Mach 1 rev limiter as well...
Kevin@Diablo
Kevin MacDonald
Calibration
www.jpcracing.com
For DiabloSport Tech Support: [email protected]
khalid80
Post by khalid80 »
Oh nice words bro any update Mr Kevin
Waiting...........
khalid80
Post by khalid80 »
I got the updat file and it works with my car
a big thanks for Mr.Kevin for his support he is very helpful
Shaken
Post by Shaken »
Kev is the man!
2003 Mach 1 K&N cai w/screen
Accufab 60mm Twin TB Steeda Tri-ax
Predator custom tune +1 lean 2k-4k, +1 lean 4k-7k
AFR 12.6-12.8 3/8" Roy Spacer IAC plate
Bassani O/R X 2.5 flowtubes to Delta 40's
w/factory tail pipes
khalid80
Post by khalid80 »
yes he is...
Return to “Predator Ford Gas”
